1985 Johnson 15 hp j15rcob
Jefffrey
just put a new spring in my rewind starter assembly. when i reinstalled it the starter pawl and spring stayed in the same location when i took it off. the spring is just hanging there can anyone please tell me how it attaches and whats it use. I am pretty sure it attaches to the starter pawl but i dont know where the other end attaches to. I am new to the outboard repair and i am learning how to maintenece it. any help would be appreciated. Jeff
flyingscott
1985 15 hp does not have a starter pawl. It has a gear that runs up a helix, what is your model #
Honorary Supreme Mariner
I thinks he is talking about the STARTER INTERLOCK ( red plastic ) to prevent cranking with too much throttle.-----And the washer must be in the proper place at the bottom of the main bolt.-----And tab on the bottom of the cup must go into the hole for proper location.----Confirm all of the above.
Are you looking for help with the red plastic starter lockout bits?----Yes or no ?
Jefffrey
Yes - that spring that I believe attaches to the starter lockout goes on there to create pressure to put it back in the open position. I think. Just guessing. I just don't know. how to install it correctly.
flyingscott
It needs to go on the opposite side of the post on the recoil. It should push the red arm away from the recoil. As the throttle advances it will push the red arm into the recoil.
Jefffrey
Hello flyingscott
Here is a pic of the starter rewind showing the red arm. inside it in a hole on the arm is a metal spring that goes through the red arm and comes out on the bottom of the red arm. i dont know what the use of the spring and if it is even working correctly or in the right place. Sorry im probably not the most descriptive with this reply. Jeff
Jefffrey
need pictures to help
here is the pic of the rewind starter. there is a red arm with a spring going through it and coming out the bottom. The bottom spring is not attached i believe it is free floating? hard to see in pic sorry. Jeff
You need a new spring for that pawl.----The red pawl is on the correct side.-----The new spring will be on this side of the metal post.
Jefffrey
Hello racerone. Jeff again. The long end of the spring is on the underside of the red arm. do you think i can get some needle nose pliers and just grab it and extend it to the metal arm? Will that longer piece be on the outside of the post or attach on the inside of the post. Thanks Jeff
The long piece goes on this side of the post.-----Your choice on how you do this.
Jefffrey
I don't know if this will help but I found this picture of my 84 9.9.
picture helped out alot. I see how the spring lays up against that post. and it looks to me like the small hook on the spring that touches the backside of the metal post does not hook to the post it just lays beside the post. big help thanks again Jeff
