1985 evinrude 150 lower unit
joe agey
Need too find out how too take the prop shaft out of the housing too replace the gear
Joe
Re: 1985 evinrude 150 lower unit
Which gear do you need to replace?----There are 4 screws inside the propshaft bearing carrier.------Then you pull that carrier out.----Then you need a big pair of snap ring pliers to remove 2 rings.-Then reverse gear falls out.
boobie
A good factory service manual would really help you. They sell them right here on I-Boats.
joe agey
both the forward and reverse. I took the boat out on a scout trip and the lower unit went out.
joe
emdsapmgr
Agree, work from a factory manual. The reverse gear is sold separately, the pinion and forward gear are sold as a matched set.
