eggs712
- May 8, 2012
- 373
Grindy Klicky hmmmm sounds...hmmm smells like New starterI've started going through my electrical system while the cabin is disassembled. The engine bay was/is a mess, but I repaired a burnt pin in the engine harness and isolated and pulled through obsolete wires.
Once I cleaned the main connections, I was able to figure out and temporarily label (all but two of) my dash switches. All lights work, gauges come on, the blower needs replaced, bilge pump hums, the horn honks, power trim works, and the starter makes a grindy/clicky sound when trying to turn the motor over.
I'll try to turn this motor over and check compression before I proceed with much else.
Hahaha! I made that username for some game as a kid, and it seems to be the only username I can reliably remember when logging in anywhere. I guess I should make breakfast on the boat during sea trials for good luck!I am the Egg Man! You can do it!
The Beatles – I Am the Walrus
“I Am the Walrus” was made up of three distinctly different songs–the first is the beginning of the song, which John was given the idea of by hearing a distant police siren. Thegenius.com
I'm really used to working on 2-stroke outboards and small engines, so I have a bit of a learning curve here. Did you jump the solenoid, or does this motor even have a solenoid?Anyway I used this before my mechanic showed up for this test. I jumped the starter and you do NOT have to run the motor. I just needed the piece of mind. The other is the spark test.
Jumper kit; Worked fine. and you can always jump it with a screwdriver if you feel good about doing that
The original two owners are passed, so a 14 year old battery in the engine bay was my only clue. I'm just surprised that the engine and drive weren't locked up!Looking forward to your compression and spark test. After that maybe a run on the engine and maybe the grinding noise will work itself out. When was the last time the piggy ran? One thing seems to lead to another lol$$
probly lost siphon. mine did. i shot a few shots of gas in it . and it started and ran. now there is fuel running up to carb. if it runs on carb cleaner just do what i did.... cheersI changed the impeller, installed a new drive belt, and changed the lower unit oil (was a little dirty at the bottom, but no metal shavings or milky oil). I added some fuel to my gas tank and tried starting the motor, but I got nothing. It fired on carb cleaner, so now it's time to work through the fuel system.
That's easy enough to try tomorrow! I'll glance at the built in fuel filter too; it's probably not the worst thing for me to be a little familiar with a little bit of everything on the motor.probly lost siphon. mine did. i shot a few shots of gas in it . and it started and ran. now there is fuel running up to carb. if it runs on carb cleaner just do what i did.... cheers
glad to hear it got goin.... sorry cant help with the leak..... thats a bummer. but glad to hear i could help in some way. cheersWith a helper cranking and me spraying gas in the carb, the motor fired right up and I let it idle at about 800 rpm. However, I noticed water pouring out of the drain hole and the temp came up to 180° degrees pretty quickly, so I had to kill the motor. I appear to be missing some plumbing, so I need to study part diagrams.
I attached a video of where the water was coming from:
looks like a freeze plug is missing? here is 2 videos might be of some use.glad to hear it got goin.... sorry cant help with the leak..... thats a bummer. but glad to hear i could help in some way. cheers
