1985 8hp Evinrude fuel pump
phaley
I'm lost. Didn't follow the simple instructions that came with the fuel pump rebuild kit ie: orientiation of inlet and outlet hoses. Took it apart, replaced gaskets, diaphram, springs etc. Put it all back together. Pumped primer bulb and fuel comes out of the vent hole in the bottom of the pump. Took it apart and checked all parts, nothing out of place. The fuel outlet I think should be on the top with the fuel inlet at about a right 45 deg. I took the pump apart several times and reassembled in different combinations and the same out come, fuel from the vent hole. Please help. Submarines Forever. Phil
phaley
Re: 1985 8hp Evinrude fuel pump
Thanks I have the diagram. Followed all but the first instruction (note the orientation of pipes in relaion to your install). Don't know if I poked a hole in the diaphram or what. Thanks
