1984 35 johnson
johns_angel
I need to know how to get the gearshift rod loose so I can get the foot off on a 1984 35 johnson outboard motor. Help!
F_R
Honorary Supreme Mariner
Re: 1984 35 johnson
I do know that the connector is behind the water intake screens on the side of the gearcase, but don't remember the exact details of how it comes apart without looking at it to refresh my memory. I suppose that must be a reminder that it is time to replace my water pump??
johns_angel
Re: 1984 35 johnson
Thanks for that bit of info, I'll try that in the morning and let cha know if it works. After i get the screens does it need to be in forward gear to get to the screw? Yeah probably huh? I'll try that .Thanks
johns_angel
Re: 1984 35 johnson
I'm gonna try that in the morning. I'll let cha know if it works. Thanks for the help.
Walker
Re: 1984 35 johnson
Pull the screens off. Unscrew the 2 nuts from each other. Slide the top nut up and remove the nylon collar.
