Woodonglass
- Dec 29, 2009
- 25,933
Re: 1983 Glastron X17 restoration
Make sure you let that PL cure a Minimum of 3 full days before you attempt to do any glass work. I will continue to cure and outgas that long and if you lay glass over it while that is still doing that it will cause air bubbles in the glass and all kinds of issues. I'd really suggest waiting 4-5 days to make sure it is really cured. How much PL did you use between the outerskin and the wood transom? Did you use a 1/4" toothed trowel to make sure you got total coverage between the two?
