Re: 1982 Johnson 15 HP starting problem
first of all. Make damn sure your old fuel is 100% gone from everything.
If you do have spark, remove the plug and shoot lighter fluid straight into the
cylinder. if it starts and then stops, repeat, this time put your hand over the carb opening ,sealing it tighter than a choke would, and it will probably suck the blockage through the system. if not, you have to remove carb and either replace the needle valve and seat or thoroughly clean a high pressure air it out.
