1982 Galaxy 16 foot bowrider TRANSOM repair questions!!!
devildogae
You will need minimum 2" thickness. To be safe, no more than 2 1/4" or the spline might not engage properly. Same thickness all around the hole, flat both sides.
My comment on two layers of 3/4" plywood was based on what I needed on my boat. The outer skin (gelcoat & glass) was at least 1/4" thick, I laminated two sheets of plywood together, added one layer of 18 oz glass between the old skin and the new transom, and then a few layers on the inside to get to 2". This is how the original was as well - but with a thin layer of glass between the two laminated sheets of 3/4" plywood that apparently served to trap moisture really well!
Thanks very much, I'll be shooting for 2" then. Great info!!
Woodonglass
Yup your outdrive Must have a transom thickness between 2" and 2 1/4" Measure the outer skin and then add another 1/16 to 1/8" for the glass you'll add to the inside and then you'll know how thick the wood needs to be.
devildogae
Thanks very much, I will do just that.
sti
It looks like the wood in my stringers is wet. One side had mush on the top, but good wet wood on the bottom. I cut it out. The other side just wet, wood is still good. I'm pretty sure I will cut it out as well. If I cut the top of the fiberglass off the wood stringer, do you think it would dry out? I went to lowe's and just scooped some wood out. I found some composite flooring that I could use that would never rot. What's your thoughts on composite materials ? Would poly resin stick to it?
I also found out that the middle stringer that goes from the drivers control area towards the bow is completely gone. But it goes under the bow fiberglass and I can't get to it. There are three total stingers in the front, and the two outside are good. Does this middle stringer, that's maybe 5 foot long, cause any real structural threat? The fiberglass is real thick around them.
DeepBlue2010
My comments are inline in Blue
No, you will never get enough ventilation for it to completely dry out and if you cut all the fiberglass, you just might as well replace it, you almost there. Wet wood will rot eventually. Better replace it while you are at it
These materials are not designed to be a stringer core. You need to use lumber or external grade plywood. If you want composite core, there are material out there that are designed for this specific purpose but they are pricey. Wood - done right - will get the job done.
Would poly resin stick to it? Did not try but again, this material is not designed for this specific application
Yes, otherwise the designer wouldn't use it or add it to the design. I think you got a full restoration on your hand but without pictures, I can't be sure. Post as much pictures as you can so we can see what you see
it doesn't matter, they are not glass stringers so they get the majority of their strength from the wood. Glass needs to be thick enough to keep the wood in place and transfer the load to the vessel's hull but not the source of the strength
jbcurt00
DevilDog, please notice when a topic was last posted to. After 90days w no new posts, consider them inactive and dont post in them. The topic you posted to asking for an update has been inactive since mid-June as has the boats owner. Not likely he'll get or reply to your post.
Any questions you wanted to ask, ask here. Most boats are built similar enough, that rebuild questions are almost the same, across most boats.
devildogae
Ok, can you help me figure out how to post pics in this thread with it showing up as an image and not a link?
