Luke000
Restoration Forum Splash of the Year 2016
Thread starter- Joined
- Aug 19, 2013
- 346
I am finally getting around to starting up my boat for the first time and the engine is running very rough. The engine has good compression (120, 123, 124), freshly rebuilt carbs and It starts up right away. However (and I had this problem when I first purchased the engine but it suddenly went away last year before I put it away) the engine pulses or surges at idle and boggs then dies when you give it throttle. It seems to act like an old hit and miss engine is the best way I can describe it. I checked the spark on all three plus and when it fires I have good spark for a second and the engine speeds up, and then it looses spark for a second and it slows down, then repeats. The only other thing I noticed is when I move the timing base all the way to the rear of the boat the engine looses speed but I get continuous spark and no more surging/pulsing. Any ideas where is a good place to start looking? Also it is a brand new battery and Im getting 13.0v when running (surging) and clean battery connections. No obvious loose or broken wires that I can see now at dusk.
