MichaelSlade
Thread starter- Joined
- Oct 11, 2009
- 5
I am getting started on restoring my new (old) boat. Please remember I have never owned a boat before and don't know all the terminolgy yet so I might end up like my wife and calling something the thingy or whatchamacallit. I picked up the boat Friday and got it home. Tried to get it to start up Sunday but it wouldn't start. I put just a bit of gas in the carb and it tried to start. Tuesday, I pulled the gas lines off and they were bone dry. Figured it must need a fuel pump. Today I talked to the local boat shop and they told me that the fuel pump needed gas in it to be able to pump. I got home tonight and filled the line and it started. Sounds good, not missing or knocking, just smooth engine purring.
I think I messed up the steering whel though. I would not turn at all and then it just gave in. Looked under the dash and the linkage moves but not through the tube like I think it should. I would think the tube needs to be connected to the steering column. Hopefully this wont be a costly fix.
My current plan is to check and make sure everything runs fine, make sure all the gauges work and have a dealer check it out to make sure it is sea worthy. Then take it out to a lake and run it around for a while to see how she runs. If then everything is fine and running good, hopefully getting started on the seats and vinyl.
Let me know if I am missing anything. Like I said earlier, I am completely new to this and will be learning along the way. I know I will probably put more into the boat than what she is worth, but I like projects like this and enjoy learning new things.
Here are some pics for my starting point...
I think I can just replace the seats, the deck and the carpet are what is worrying me.
I will post more as I get farther into it.
Michael
Michael
