1979 rude 85
smith88
To adjust the shift rod does the control need to be in reverse?
Joe Reeves
Re: 1979 rude 85
Lower unit must be removed.
Measurement must be made from the top surface of the lower unit to the center of the shift rod hole.
1979 thru 1981 V/4 models = (L) 21-27/32" - - (XL) 26-27/32" Have shift rod in neutral (IN NEUTRAL).
smith88
Re: 1979 rude 85
Thanks Joe, Pulled lower for pump, think we maybe turned linkage.
smith88
Re: 1979 rude 85
Joe,Just realized I gave the wrong year.It's a 1975.Sorry
Joe Reeves
Re: 1979 rude 85
The 1975 V4 engine does not have an adjustable shift rod, just a threaded barrel on top of the rod. Screw the barrel all the way down, then back it up just enough so that it is facing properly.
smith88
Re: 1979 rude 85
Thank you Joe, working great now.Thanks for the help.
