To adjust the shift rod does the control need to be in reverse?
S smith88 Cadet Joined Aug 25, 2011 Messages 15 Sep 4, 2011 #1 To adjust the shift rod does the control need to be in reverse?
Joe Reeves Supreme Mariner Joined Feb 24, 2002 Messages 13,262 Sep 4, 2011 #2 Re: 1979 rude 85 smith88 said: To adjust the shift rod does the control need to be in reverse? Click to expand... Lower unit must be removed. Measurement must be made from the top surface of the lower unit to the center of the shift rod hole. 1979 thru 1981 V/4 models = (L) 21-27/32" - - (XL) 26-27/32" Have shift rod in neutral (IN NEUTRAL).
S smith88 Cadet Joined Aug 25, 2011 Messages 15 Sep 5, 2011 #3 Re: 1979 rude 85 Thanks Joe, Pulled lower for pump, think we maybe turned linkage.
S smith88 Cadet Joined Aug 25, 2011 Messages 15 Sep 5, 2011 #4 Re: 1979 rude 85 Joe,Just realized I gave the wrong year.It's a 1975.Sorry
Bob_VT Moderator & Unofficial iBoats Historian Staff member Joined May 19, 2001 Messages 26,112 Sep 5, 2011 #5 Re: 1979 rude 85 http://forums.iboats.com/showthread.php?t=158088
Joe Reeves Supreme Mariner Joined Feb 24, 2002 Messages 13,262 Sep 5, 2011 #6 Re: 1979 rude 85 smith88 said: Joe,Just realized I gave the wrong year.It's a 1975.Sorry Click to expand... The 1975 V4 engine does not have an adjustable shift rod, just a threaded barrel on top of the rod. Screw the barrel all the way down, then back it up just enough so that it is facing properly.
S smith88 Cadet Joined Aug 25, 2011 Messages 15 Sep 8, 2011 #7 Re: 1979 rude 85 Thank you Joe, working great now.Thanks for the help.
