Re: 1979 22' Starcraft SuperSport V5 Restoration
Didn't do any actual work on the boat this weekend, but I did get and engine stand built. I used the plans posted on Iboats as a guide.
I was expecting something a little more complicated for a pick-up on the gas tank but when I took the fitting off, it's just a tube thats part of the welded on bung that goes to the bottom of the tank. The second one just had a plug in it. I assume thats there in case you ran twin engines.
The kicker that came on the boat is a long shaft that sat on this ugly bracket. Any reason why I can't convert it to a shortshaft and just hang it on the transom without the ugly bracket. It would look a lot cleaner and the height difference from the transom to the ugly bracket is 5", which is the difference between a short and long shaft.
