Ok using joe reeves method I set my timing to 22* alloting for the 4* for normal operating so I don't damage pistons. Next step I'm confused on, it says:
Now...... after you've untied the timer base etc and have the vertical throttle arm fully retarded.... Start the engine and move the throttle (vertical throttle arm) to wherever it has to be in order to start and have the engine running. Now, with the engine running, turn the idle stop screw in to wherever it must be to keep the engine running at a proper rpm.
If a 20" shaft, and running on a flushette, idle at 1000 rpm....... if a 25" shaft, idle at 1200 rpm.
Am I supposed to be doing this with the timing advance lever hooked back up into the plastic bushing because I unhooked it to set the timing at wot.
I tried setting my idle rpm to 1200 but the lowest I can get it is around 1800 and that's with me pushing the timer base piece as far back is it will go with my finger. What am I missing here?
