1978 85hp Johnson timing issues
98SkeeterSS90
Rebuilt the carbs on this and it has idled extremely high since. Just put a timing light on it and it says it's idling at 3000 rpm!!!! How in the heck do you adjust the timing on this junk? I got my seloc manual but I can't find anywhere in there in the timing and synchronization section where it specifically says how to adjust the timing. I've read that the idle rpm is directly affected by timing. Can someone PLEASE HELP ME WITH THIS BOAT BEFORE I GO CRAZY!
1. Is the timing affecting idle rpm???
2. How do you adjust the timing exactly? This seloc manual I have is EXTREMELY vague on what to do.
3. Please help me get this idle rpm down! I'm seriously thinking about throwing this motor over into the river and just giving up.
Sorry but I am just extremely overwhelmed and frustrated with this whole ordeal getting screwed on this boat purchase
flyingscott
Find the idle screw on the timing arm and back it out. It could also be the throttle cable itself is not adjusted right.
98SkeeterSS90
This piece the screwdriver is touching I believe is messed up. It doesn't move at all when I give it throttle. I unhooked the cable connecting to it and manually moved it and the motor fired right up but idled extremely high. I think this connects to flywheel and adjusts timing. Any reason this would get stuck and not move when giving throttle??
flyingscott
That is supposed to move and I can see the gap between the idle screw and timing arm. Find out why the timer base is not moving.
98SkeeterSS90
Also the timer base seems extremely hard to side/turn/move when I disconnect the cable that attaches the the throttle arm/shift arm assembly thingymajigger
interalian
That should move silky smooth. If it's sticking, you'll need to take off the flywheel and remove the timer base, then clean and re-grease it.
Did you ever see this motor running when you purchased your rig?
98SkeeterSS90
only saw it idle on muffs, seemed like too good of a deal to pass up and it turns out this is why it was so good of a deal. But the guy conned me. I just need to get it running, I've come to the conclusion that I was screwed I just need to make the best of the situation.
I'll buy a socket big enough to remove flywheel. Any tips on holding the flywheel still while turning the nut?
98SkeeterSS90
Also I sprayed some electrical contact cleaner around the base and it free'd it up a little so taking flywheel off should help tremendously.
After I free it up smoothly, how is the idle adjusted?
interalian
You need a strap wrench or a flywheel holder. The nut is an oddball size, but I found a 34mm 6 point cheap at the auto parts store worked just fine.
interalian
You also need a harmonic balancer puller to get the flywheel off - fine pitch bolts. Loosen the nut but leave it threaded to prevent the flywheel popping off when it lets go. Imperitive to use a torque wrench to re-install. I believe the spec for that is 100-105lb/ft.
interalian
The cleaner probably loosened and re-activated the dried up grease. You may be lucky and don't need to remove it and clean if it stays loose and smooth.
Idle is set using the slotted screw facing forward, just above the throttle arm pivot point. Make sure both throttles are closed and there's a gap between the roller and cam.
flyingscott
Spray the base with a penetrating oil it will help dissolve some of the grime and maybe loosen it up more.
98SkeeterSS90
Just ordered omc 395448, broke the plastic clip that holds the spark advance rod (just my friggin luck!) so kinda stuck right now, I guess I could rig so I can continue working on it but I still don't know how to set the timing, like I stated the book I have is very vague, does anyone have a link for setting the timing on my specific motor? Thanks in advance
98SkeeterSS90
Will the motor spin fast enough with the spark plugs out to give me a reading on my timing light?
98SkeeterSS90
Got it idling around 1700 now can't seem to get it any lower, the timing screw is backed almost all the way out
