1978 85hp Johnson timing issues
interalian
Sounds like we're back to getting the flywheel off, not just to check the key but to clean and lube the timer base. Harmonic balancer pullers are cheap cheap cheap. The kits usually only include coarse bolts - you'll need fine.
98SkeeterSS90
I cannot for the life of me get this flywheel off! I can't afford the tool to remove it, especially for a one time use kinda tool. This boat motor is cursed!
98SkeeterSS90
I got a balancer puller and fine thread bolts (I used 5/16-24) I just can't get the nut loose. Prying a screwdriver in one of the marks in the flywheel (not the teeth) ain't cutting it. It's 100-105ftlb tight not to mention a layer of rust that I've sprayed for two days
oldboat1
Use some PB Blaster and an impact wrench, if you have one. (If you use the rattle gun, you don't need to hold the flywheel.)
[Edit. for the flywheel nut.]
interalian
I'll admit I jerry-rigged a way to get my flywheels off: the lifting eye on the back has too much of an angle, but if you loosen the two bolts holding it down you can rotate it to provide a vertical holding edge for a thick screwdriver or prybar. Tighten the one bolt in with the eye's edge vertical and put a block under the other side to keep it from moving. Removal was with a 12" adjustable wrench. Installation was with the 34mm socket and a proper torque wrench. Shouldn't be that hard to remove once you have the flywheel held. Make sure you hold the prybar straight so it puts force on the root of the flywheel tooth, not the tip.
oldboat1
On the flywheel nut -- an alternative to using an impact wrench is to whack the end of your wrench or socket wrench handle horizontally, using a heavy hammer. Again, can usually break the nut loose without having to secure the flywheel. Wear heavy work gloves for any of this stuff. Ring gear gives nasty cuts.
interalian
A helper can be good - one to hold the prybar, one to swing the wrench. We're pullng for ya.
Bosunsmate
you can take a piston down to bottom dead centre and then feed in some rope, as the flywheel turns it compesses this rope and then stops, allowing you to put the necessary tension on the nut to remove it.
But dont remove it the whole way. Keep it on there near the top of the threads to stop the flywheel flying off once the puller releases it
98SkeeterSS90
Thanks for all the tips guys, gonna give this another go when I get off this evening
98SkeeterSS90
Ok using joe reeves method I set my timing to 22* alloting for the 4* for normal operating so I don't damage pistons. Next step I'm confused on, it says:
Now...... after you've untied the timer base etc and have the vertical throttle arm fully retarded.... Start the engine and move the throttle (vertical throttle arm) to wherever it has to be in order to start and have the engine running. Now, with the engine running, turn the idle stop screw in to wherever it must be to keep the engine running at a proper rpm.
If a 20" shaft, and running on a flushette, idle at 1000 rpm....... if a 25" shaft, idle at 1200 rpm.
Am I supposed to be doing this with the timing advance lever hooked back up into the plastic bushing because I unhooked it to set the timing at wot.
I tried setting my idle rpm to 1200 but the lowest I can get it is around 1800 and that's with me pushing the timer base piece as far back is it will go with my finger. What am I missing here?
Bosunsmate
im not sure about all that but 1800 is way to0 high. Hows the timing stop screw, have you tried winding that back so the timer base can go back further?
Have you checked flywheel keys ok by lining flywheel tdc with the pointer on engine and checking piston one is at tdc?
98SkeeterSS90
I can slide a piece of paper between roller n cam, I still have yet to get the flywheel off, I'm trying to find something to hold it still while I turn nut. Do we have any members here in Alabama? I'd be willing to drive it to show someone in person. This has gotten so overwhelming I'm about to go crazy. This stuff shouldn't be this hard!
I got a new updated timing advance rod plastic bushing/holder on the way mine is jerry rigged right now cuz it broke but still shouldn't cause all this.
98SkeeterSS90
Also I can't adjust that can roller much more and keep it lined up in the middle of the embossed mark
98SkeeterSS90
Also, discovered this while taking pictures,
It only has one bolt in it and I can wiggle it side to side due to it not having the other bolt.
Bosunsmate
To check your flywheel is ok just check that the 0degs mark lines up with the pointer beside the flywheel and that your motor top cylinder is at tdc then.
Your idle stop looks adjusted all the way out. At that rpm and that timing something is wrong
Bosunsmate
Also in that last photo where you say you can wiggle something, that looks like a rectifier but dont bother about that now. There are also two holes there around it which seem to have being partially filled. You need to check that none of those are open holes, ie they dont go into the engine. If they do (they look like they have being attempted to being blocked up, they will let air in and thus cause a lean mixture and a high idle.
Also check that hole with the missing bolt in case it goes right through too
