FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
When rebuilding did you just do the one piston or did you disassemble the whole thing?
The fuel recirc system was it cleaned?
Timing.
Wrong carb setting.
Overheating, poor water circulation.
Sucking air.
Fuel pump not sealing on block.
Bad reeds.
A few things that can make it go bad.
Yes that is correct, I just replaced the middle piston last summer. I did not clean the carbs. I am thinking I should change the fuel lines and primer bulb, it may be sucking air. Is there a good spot for piston purchases.
