1978 75 HP Chrysler piston replacement
charakel
Back to the drawing board. 2nd piston replacement within a year. 1978 75 HP Chrysler piston replacement. See pic. What is causing this??
Nordin
That looks like predetonation.
Are the carbs cleaned?
How are the air/fuel mixture screws set?
What is the timing advance at WOT?
Air/fuel screw should be 1 1/4-1 1/2 out from seated. NOT less then 1 turn out!
Timing advance 30 dgr BTDC.
jerryjerry05
When rebuilding did you just do the one piston or did you disassemble the whole thing?
​The fuel recirc system was it cleaned?
Timing.
Wrong carb setting.
Overheating, poor water circulation.
Sucking air.
Fuel pump not sealing on block.
Bad reeds.
A few things that can make it go bad.
charakel
Yes that is correct, I just replaced the middle piston last summer. I did not clean the carbs. I am thinking I should change the fuel lines and primer bulb, it may be sucking air. Is there a good spot for piston purchases.
jerryjerry05
I buy Wiseco pistons.
​They need no special tools to reassemble.
You do need their wrist pin and other recommended parts.
