tgordon1234
- Sep 21, 2013
- 82
i picked up a 22' starcraft i believe its an islander today, it has a 250ci gm motor that doesnt run and hasnt run in nearly 3 years spins by hand i did what i could to turn it over by hand (only was able to a little bit) it appears someone has been in there before things are changed and rerouted ect. floor is soft. anyway got the thing home determined the starter is no good cant figure out how to get a socket or wrench in there to remove the damn thing. while crawling around in the engine compartment i notice the transom is heavely rotted. couldnt see it that well when i looked at it prior to buying it but i took a gamble. well low and behold its rotten. solenoid for trim down is no good (not a big deal) basically im asking all the experts here how bad is it do a transom im aware the motor and outdrive have to be removed. i wanted to put a starter in it and make sure it ran first but i cant get to the damn bolts. i paid 500 for the thing with a trailer. i know what the cost new my dad bought a 21 foot brand new in 2001 but time is an issue for me as well as dumping a lot of money in it. interior is pretty rough too.
haul is solid no corrosion or dents or anything that i can see. looks like a hack did motor work on it though lots of loose bolts and brackets ect.
