Cadwelder
- Aug 30, 2010
- 1,780
Re: 1977 Cheetah 17' Ski boat restore
I personally wouldn't do it on the trailer, some have and got by okay. I just build a cradle out of some 2x4's and it works great. $40.00 worth of lumber and once you're done you can use the 2x's for whatever around the house or shop. The problem is the hull becomes flimsy once all the internals are removed and it's easy to build a "twist" right into it. If you go with the work on the trailer at least add some supports of some sort to maintain the hulls orginal shape.
And you can also check out and repair the trailer easily while the boat is off of it.
Will i be able to work with it on the trailer? It seems that would give it the most support. Or do i have to build a thingy ma bobber to hold it? I really need to save as much as possible.
Thanks
