george1972
- Apr 30, 2009
- 2
Long crazy story herebought this motor from a fella that had it sitting for quite a while in his yard,tried cranking it,turned slow,thought starter was shot,got a different starter an arco remanufactured,same thing,pop the plugs out cranks fast,put them in barely turns,but once in a great while(rarely turns normal) it will crank.I can start the motor with the rope tho.jumped the starter direct off of my truck,same thing.took starter off,had it checked by a rebuilder,we cleaned it,tested it,tested ok,he says nothing wrong with it,help me out guys,what else could cause this if I bypass all the electrical system,and still have the problem?
