1976 evinrude 15hp
Logo09
Re: 1976 evinrude 15hp
Replaced the points and condensers and still no spark. I am going to replace the spark plugs just for the hell of it. I removed the plate that holds the coils and inspected the wires that ran out the bottom of it, and also removed the rubber sleeve to make sure that there were no cracks or breaks in the wires.
Logo09
IT WAS THE SPARK PLUGS THE WHOLE DAMN TIME!!!!!!!!!!!!!!!!!!!! I tested a spark plug from my lawn mower and i got the best blue spark! i was about to take it to a mechanic and this was my last act of desperation! I am so happy right now!!!!!!!!!!
Logo09
well the good news is that the motor runs (two new spark plugs). runs pretty nice actually. But for some reason it wont run unless i have the spark plug boot pulled off just slightly. i am gonna have to pick one of those testers up. Also For some reason i am not getting any water out of the water hole.
Logo09
Just talked with a local mechanic and he said i should use Champion L86C instead of the Champion UL81C plugs i just bought.
bonzoscott
You should take your time, don't get in a hurry, search throughout the forum. If it's not pumping water it will be a quick demise.
Logo09
Just picked up a tester and the right plugs. lets see what happens
Logo09
Impeller is good. not sure why im not getting any water out the back. How should i troubleshoot this?
Logo09
take a look at this photo. i held my garden hose up the the water exhaust port to see if i could get water through the system. i did but water wasnt coming just out of the pipe. a lot of water was coming from around the pipe as well. is this bad?
http://i.imgur.com/rBzf7.jpg
eoitker
I read this whole thread and I'm glad you got your motor running. I'm currently having a similar problem with my Evinrude 9.5 hp Sportwin. When I first got it, I was getting 1 spark now neither will spark! I will go through the step you did and hope I am as lucky. Purchased new plugs, this evening!
