Arawak
- Aug 27, 2010
- 486
Full album on Google+ <---- I'll keep updating this for those who want to see all the photos
Ok, so I really did intend to part this out when I bought it.
But, after walking past it every day in my garage the itch started, and now, well..... I do need a winter project...
So, with some difficulty I got the lower unit off. The drive shaft was stuck, but with just two bolts loosely holding it on, I rocked the flywheel back and forth sharply a few times and got it off. Took off the water pump housing, removed the impeller and the gasket. Vacuumed out a ton of debris (acorn shells!). Ordered new impeller and gasket, should have sometime next week.
At this point I'd like to check the compression. Any reason I can't turn it over with the LU off?
