- Oct 25, 2011
- 25,265
Re: 1976 Arrowglass transom replacement and then some
If you have any misgivings about the paint prep, it's application or how well it's currently stuck to the gelcoat, it'd be best to remove it w/ a combination of sanding & stripping. CitriStrip says it's gelcoat friendly. It would be great to leave it, but you'll never know how good a base coat it will provide for your paint until it doesn't. And even for just a $100 paint job per WOG's link, there will still be lots of prep to leave the existing. I'd rather spend the time & effort now, and never wonder if about the existing paint.
Don't be surprised if the gelcoat is a wreck, it often is, that's why so many get painted. So that'd be another reason to remove the existing paint, you can address any areas of questionable gelcoat too.
Whatever paint you plan to finish with, use their primer. The paints & primers all work as a system, so stay w/ 1 system. There have been both glass & tin boats painted w/ the Majic/Valspar paints from Tractor Supply (WOG's link) and as long as the mixing, ratios & 'cook' time are followed, I've not read any bad reviews about either paint. The last 'complaint' was some runs, but Magnumdeke ran short of paint & didn't let the last batch cook long enough before he shot it. I don't remember having Tractor Supply in the Louisville-Lexington corridor so I'm not sure if you'll find the Majic paint line. Valspar's Farm Implement line used to be carried by TS, but it was successful enough that they introduced their own brand, Majic. You should be able to find the Valspar FI or at least someone who carries Valspar & can get the FI.
The addition of the hardener increases the sheen level of the paint & it's resistance to abrasion, and can be used w/ other paints. Rustoleum Pro is another paint used frequently.
But it is paint, not gelcoat & will scratch. WOG scratched his BFF's bow working around it in the garage pre-splash, and nicked the keel getting it on or off the trailer at splash. But it's paint and with good weather and some time over a weekend, it can be touched up, inexpensively
