Seasonally.boating.jon
Thread starter- Joined
- Jul 10, 2011
- 283
Re: 1976 Arrowglass transom replacement and then some
Lil' man sitting there thinking about it.
Earlier this week, I scrubbed the crap out of this hull. What worked really well for me, to get the hull clean, I used a scrub brush, lots of rags, and ofcourse acetone. I simply pured the acetone on a the little area I was cleaning, scrub really fast with the brush, before the tone dried, I wiped with a rag. If you wipe before the tone dried, the dust will stick to the rag better. I did shop vac the hull prior to the deep cleaning.
For the limber holes I know alot of people use the pvc pipes. I'm in sort of a debate with myself.
1: Smear PB on the limber holes before I bed the stringers in. About 8th inch thick.
2: Use a piece of 1708 and line the hole.
Instead of useing the wax additive, I'm going to buy a gallon of the resin from the home or auto stores to water proof the holes. Use it with the cloth or to mix the PB. Not a major debate, just some thoughts that have been going through my head wile I'm fine tuning everything.
