jrolland
Thread starter- Joined
- Jun 11, 2008
- 86
This past June my Dad gave me his 1975 Sea Ray 190. It's has the potential to be a great boat it just needs a little TLC. I started working on it over the summer trying to get it ready for the water but I cut a tendon on my left hand in July so that really slowed down the process. By the time my hand was 100% it was time to winterize her. So now I have to wait until spring to do any more work on her. My plan is to restore it with the help of some friends.
Before I picked up the boat my Dad warned me that it has been sitting for a few years so it will need some work. I prepared myself for the worst and went to look at it. To my surprise the boat was not in bad shape. It was dirty but it was still shiny and luckily for me covered. Although the cover did have a few tears in it. When my Dad said it had been sitting for a few years I thought maybe 3 or 4 tops well it had been about 8 years since it was last registered and in the water. I took it home anyway because I have always loved the boat and thought I could do the work. After getting it home I cleaned it up and checked things so I could try and get it running. After a trip to the store for a new battery, all I got was click...click. I messed with it for the rest of the day and gave up. I called a friend of mine who owns a local marina and took it down there. They messed around with it and finally got it running. When I went to pick it up I was told it was going to need a few things. I braced myself and was told it would need a new starter, fuel pump, trim pump, plugs, wires water pump, all the bellows and the carb should be rebuilt. In addition to the mechanical the interior had seen better days.
I was not afraid of the list I was given because they told be that most of it can be done me. I have not replaced everything but I have replaced some things so far. So far the fuel pump along with a new fuel water separator, plugs, wires, some hoses, the trim pump (which will trailer up but won't go down or up) thermostat, and right now the outdrive is getting a new water pump and shaft seal because when I pulled it off there was O/D oil coming out. Also upon removing the O/D I discovered I will need to replace the shutters on the exhaust.
At first I was a little worried about the age of the boat and all the work that needed to be done but the marina that worked on it said I should do it. They told me that at some point the boat had been repowered and the newer engine has great compression and runs great. Not only that but the hull is in good condition for its age.
Right now there isn't really too much more I can do until spring. So for now I am working on some of the interior pieces. This winter I plan to refinish the teak trim pieces I was able to remove as well as rebuild some of the wood side pieces that were rotten.
Below are some pictures that show what the boat currently looks like. I know there are a lot of people on iboats that like the old rays so please feel free to give me your opinions and even some suggestions for the restoration. I am open to almost anything.
