1975 sea ray srv 193 images
1975 SRV 193
Hello everyone, I am a new member and need some help. I recently acquired a 1975 Sea Ray SRV 193,It must be a rare model because I cannot find one single picture of one,I need some interior images of bow are back seating area interior in general. Mine has some pieces missing and i want to know where to start and what it should look like so i know how to put what where. I would greatly appreciate any help. Thanks
southkogs
Welcome aboard. I'm not sure Sea Ray had a model in '75 called a 193. I think the 193 was done by '73. I'm thinking you've actually got a 190 (if it's a '75).
That said ... LOTS of the parts you need to replace are typically "rigging" that is not manufacture specific. What parts are y'a trying to fix. Chances are it doesn't matter on the specific model.
1975 SRV 193
The badging on the glove box shows SRV 193 and im pretty sure the title does as well,i will double check. thanks
1975 SRV 193
the anchor well or whatever it's called has the hinge there with screws all the way across the hinge but no cover there at all,and im curious how the seating arrangement in the bow area goes.
1975 SRV 193
I will take a few pictures to post today, can i attach regular pictures here or is there a specific way and place to do this? Thank you so much for your response.
roffey
Take a picture of the HIN as well... these guys and gals will come up with all sorts of information for you.
southkogs
"How to" for the photos is HERE.
Check for a HIN on your registration, but also look on the stern of the boat (usually stamped into the fiberglass, just under the rub rail). HINs weren't required until later in the 70s. So, if there's one on the boat then you're likely that '75 year. If there's not a HIN on the boat, it's possible that the boat is earlier than a 1975 too.
1975 SRV 193
So here is an image of the glove box. Zoom in to see the badge ID
1975 SRV 193
Here are a couple more pictures, the HIN # and the right and left side view of the bow area where seats should be and an image of the anchor well with the hinge on back side with screws for attaching lid. Think it has some sort of cover with teak wood strips,not sure I cannot find a single image of an SRV 193 BR!
1975 SRV 193
[No message]
1975 SRV 193
ok, the first image here is left side of bow seating, second image is of right side bow seating area. im assuming since I have no pictures of an SRV 193 BR.
1975 SRV 193
I have the original title it says and the year is 1975, it's a 1975 sea ray SRV 193 BR tri hull title shows.
1975 SRV 193
If anyone can come up with an image of this model boat for me to reference to for different things,especially the bow are where things are missing i would be very appreciative. I have a lot of work ahead of me,stringers are rotten etc I have started cutting up the deck and ripping out wet foam already,look forward to help from you guys. Thanks to all.
southkogs
Do a little lookin' HERE. Looks like the 1975 brochure is missing, but the '76 is there and has a 193 in it.
1975 SRV 193
Thanks for the link,all it shows in one image from a distance and no interior pictures at all,not much help.I will keep hoping and looking,there has to be a 75 srv 193 out there somewhere!
