1975 Merc 500 shut-off at WOT
boatmanwayne
After decarbonizing powerhead & exhaust on 50 hp, when I run at 3100 or higher rpms engine shuts down like the key is being turned on and off, throttle back a little it runs fine. Checking timing I find timeing goes from 35 BTDC back to around 15-20 BTDC when advancing throttle past 3100 rpms. Could my switchbox be going out?
12Footer
Re: 1975 Merc 500 shut-off at WOT
Check the tanks ,carb bowls for water . Check tank vent to.Does primer bulb go soft when it does this?
boatmanwayne
Rechecked all fuel possibilies everything is good to go, Also all coils have been replaced due to previous problems. distributor & wires clean and good,timing is set. Is there a test for the switchbox other than ohms test I could do?
