Phillabaum
Thread starter- Joined
- Aug 29, 2011
- 40
Got the engine running great 130 psi all cyl. Problem is just burned up my 3rd starter. First one was original, second one the store said they are making them cheap now and replaced free of charge. Now that one is toast. I heard the bendix not engaging the flywheel properly, Keept trying to start it then nothing (I think the 2nd one showed signes of the same thing on the bendix). I don't see how you can adjust the distance the starter is from the flywheel. So what could be causing this. I have no reason to belive the flywheel is incorrect. and the ring gear looks to be in great shape. Is it possible I am getting a starter with the wrong bendix? (everytime). I am going to take it appart I think the brush is locked up. Turn the key and nothing happens now.
So far
I have replaced the stator, rectifier, and 3 starters. need to order a power pac. and then go ahead an replace the impeller. Although its cooling ok and spitting water it would still be a good idea.
FIRST I NEED TO FIX THIS STARTER. I WANT TO FISH.
So far
