bobothewizard
Thread starter- Joined
- May 8, 2007
- 42
I melted my trolling motor plug today on my 71 thrust motorguide while out on the lake and I was wondering if any of you guys could share some insight on why?
I have the big female to male plug and while out on the lake today the male part of the plug started smoking and basically melted. Im a little curious why the breaker in the back of the boat didnt trip and the wires in the back connected to the batteries were not even warm.
Now the weird part is, I got home and took the prop off to check to see if i had any fishing line or stuff around the prop shaft and I did not, but after running the motor without the prop for about 2 minutes the shaft where the prop screws on got fairly hot almost to hot to touch. Im wondering if maybe the lower unit itself is going bad? Or is this normal when the trolling motor is out of water and running? Maybe the shaft itself is water cooled?
Anyway, im on my way to pick up another plug tomorrow but im wondering if there isnt something wrong with the motor itself?
What do you guys think?
---- After doing a little more investigating on the forums here its a 4 prong twist lock plug. I wonder if i didnt twist lock it down, since i havent checked it in a long time it might have wiggled loose? Would that maybe have it melt?
Thanks in advance!
Thanks in advance!
