1975 70 hp johnson misfireing bad please help
gwinvadr
first time here so take it easy.Ive got a 1970 70hp Johnson it was sitting up for 2 years then i got it u can put it in the water crank it up and it runs but when u put it in gear at about 1/4 throttle then it starts misfiring acting like its running on 1 or 2 cylinders Ive cleaned the carbs put kits in them all the jets are clean the advance it works it moves freely with the throttle linkage and im getting blue spark to all cylinders i ohm'd out the coil packs found one that was fluctuating so i replaced it did not change nothing. please help
Daviet
Re: 1975 70 hp johnson misfireing bad please help
Whats the compression like?
You can use an inductive timing light to find out if all the cylinders firing.
If you have good compression and spark, fuel must be your problem.
tashasdaddy
read this---http://forums.iboats.com/showthread.php?t=158086,
Did you remove and clean all the jets, and use rebuild kits?
http://forums.iboats.com/showthread.php?t=330129
http://forums.iboats.com/showthread.php?t=313963&highlight=compression
http://forums.iboats.com/showthread.php?t=244013
http://forums.iboats.com/showthread.php?t=299680
spark plug wire on correct cylinders. have you check to make sure the flywheel key is not sheared? causing the motor to be out of time.
tashasdaddy
all three cylinders could be firing, but not running, due to lack of fuel. motor running, using insulated pliers, pull and replace each spark plug wire. if cylinder is "running" you will notice a drop in rpms. if no change, then that cylinder is not "running. those motors have been known to idle on just one cylinder.
gwinvadr
kits in all three carbs and the compression is 115 +or - 5 to 10 psi on the cylinders
gwinvadr
i have a spark tester and im getting a 7/16 blue ark
gwinvadr
when the engine starts misfiring you can look in all the carbs and see the high speed jets in action with a uniform spray pattern
Daviet
Pull one plug wire at a time and find out which cylinder is not firing, squirt some oil/gas mixture into that carb and see if it picks up.
If it fires by squirting fuel into the carb, you have a fuel delivery problem with that carb.
gwinvadr
i did the timing light and pulling plug wires and spraying gas oil mix in the cars yesterday the timing light flashes on all cylinders the gas makes the motor stall and pulling the plug wires one by one make the motor change it tune im stumped
AlTn
as TD stated....seems like it's time to pull the flywheel and check for a sheared key, or possibly a wire that is worn or bare and is shorting when the timer plate is in the 1/4 advanced position
gwinvadr
would a small hairline crack hurt the coils think its called a high voltage leak
gwinvadr
need some ideas anyone
Daviet
Are you checking with a timing light or pulling plug wires while the miss is occouring or at an idle?
AlTn
yes to your coil question...the sparkplugs need full voltage to jump the gap as the load put on them increases
gwinvadr
i checked with a timing light and pulled wires there still sparking and lighting up the timing light
gwinvadr
i was going to do a sensor coil test but i do not have a neon test light what else can i use to do that
Craig-
Is the wiring harness in poor condition? They can get bad at that age.
gwinvadr
the wiring harness is in great shape
gwinvadr
what is a neon test light
Craig-
Try running it in the dark and look for any arcing. Clean all grounds shiny.
Check flywheel & timer base. You covered the rest, unless you have a wacky pack or poor connections at the pack or terminal block, ohm everything out.
