crankbait cowboy
Thread starter- Joined
- Mar 25, 2013
- 621
any ideas as to how to remove the drain tubes and plug hole in transom, as i want to tear out old and replace. also wondering do i put new transom in, dry fit, and drill all holes needed, then remove and drill holes out bigger,fill with 5200 and then put together drilling new holes. hard for me to follow exactly what procedure you other guys are doing. thanks in advance. will have some pics of the transom coming out
started taking off old glue from gunnel storage area. using drill and an 80 grit sandpaper disk. seems to work real well. as you can see in 2nd pic it leaves pretty good scratches. should be fine for this area and cleaning up bottom of boat as it will all be covered with floor or vinyl. but wondering if this would be an issue for any place i am going to paint (scratches) any thoughts from you all?View attachment 212103View attachment 212104
got 2 coats epoxy resin on bottom and 1 on top of deck boards. (will put a final coat on top when installed filling all seams real good. took advantage of nice weather but gonna be awhile before i get floatation/fuel tank and deck on so shoould cure real well.
