wmgraphics
Thread starter- Joined
- Jun 30, 2008
- 47
I bought a 1973 115hp - M#- 115ESL73M S# - J3867259 (what does the "m" stand for in 115ESL73M?)
I need a repair/parts manual that is easy to follow. Engine has sat for several years. The tech I hired to inspect the boat said it had good compression, spark, lower end fluid looked good.
The things he found wrong was... fuel pump was not working. He said the rubber most likely fell apart after sitting for so long. Should I get a repair kit or just by a new/rebuilt one. He said to repair can be a real pain.
The starter was bad. He said something about it giving off a big surge when he tested it. Could this be a solenoid problem? Should I just replace it or repair kit and where can I find one.
The carbs should be rebuilt. Where can I find these (2) and what should I really be looking for in these kits?
Should I change the lower end fluid and seals?
Other than spark plugs, impeller and maybe thermostat is there anything else I should replace/ check or do to this motor before attempting to start it? I'm kinda nervous since it sat for so long and I am not the most mechanically inclined dude. Please help.
