scottrbishop
Banned
Thread starter- Joined
- May 15, 2007
- 81
Greetings, I have a 1973 Glastron GT150 15' with an 85hp Merc outboard of the same year. Everything runs well, except when skiing with about 450lbs in the boat, when I go from lowest speed to WOT to plane out and get the skier up, the motor just dies. If I go slowly (not quite fast enough for a skiier), it will struggle past a certain point and then go at full speed, but I can't get a skiier out of the water which is the reason I bought the boat. I changed a couple spark plugs that needed replacing, put in a new fuel line (the gas can is not built in) and impeller this spring, and it does not seem to have this problem with nobody skiing, so I think the load is what's causing it to die, but I just don't know why. Does anyone know what could cause the motor to act this way? Any advice would be much appreciated. Thank you in advance,
Scott
Scott
