1973 85hp Merc dies WOT
scottrbishop
Banned
Greetings, I have a 1973 Glastron GT150 15' with an 85hp Merc outboard of the same year. Everything runs well, except when skiing with about 450lbs in the boat, when I go from lowest speed to WOT to plane out and get the skier up, the motor just dies. If I go slowly (not quite fast enough for a skiier), it will struggle past a certain point and then go at full speed, but I can't get a skiier out of the water which is the reason I bought the boat. I changed a couple spark plugs that needed replacing, put in a new fuel line (the gas can is not built in) and impeller this spring, and it does not seem to have this problem with nobody skiing, so I think the load is what's causing it to die, but I just don't know why. Does anyone know what could cause the motor to act this way? Any advice would be much appreciated. Thank you in advance,
Scott
redjmp
Re: 1973 85hp Merc dies WOT
Try backing out the idle mix screws 1/4 turn and see if that helps. Try 1/2 turn as well. Try sqeezing the ball a few times. If no improvement test for good spark on all 4. What is WOT rpm's? Check compression. Good compression and good spark means its a fuel problem. Time for a carb overhaul. Make sure you blow out all the passages with compressed air.
Check your link and sync as well. There is a good article in the FAQ section by Clams Canino on ho to do this.
scottrbishop
Banned
Thanks for the info redjmp, Im going to rebuild the carb this weekend, does anyone on here know of a good place to get a carb kit for this year of motor? Also, I think my guage must be broken because it tells me that WOT rpm's are around 3,000, which is way low from where I understand it should be. Any other suggestions? Thanks again for the response, there's a great wealth of information on here!
-Scott
papasage
N A PA auto parts can order them .
