1973 7 hp Eska
Sniperdoug1969
I am Restoring a 1973 Eska outboard. My question is this I retrofitted it for a Evinrude gas pipe hook up I am wondering how the fuel pump works or even if it has a fuel pump. How does this engine get its fuel from and External tank to the carburetor? Thank you to anybody that has any advice
matt167
if it was top tank, likely has no pump. if it does it's a pulse diaphragm in the carb
brim_buster
On the inside face of the carb that faces the power head is a reddish pink fuel pump bladder.
Its found in the carb kit if it needs replaced.
