Hello,<br /> I'm new to to the forum so try to bare with me. I have a 1973 115 V-4 evinrude. It runs great at high rpm's, but when I come back to idle it sneezes trough the exhaust. New plugs(Champion L77JC4) , getting good fire, carbs have been cleaned by myself and an outboard mechanic. He tried to idle it up just a little and still nothing. He told me to crank it up and spray starting fluid around the powerhead to check for air leaks (I was told it should idle up if it had a leak). Did that and nothing. Compression is between 136 and 140psi(all cyl), fresh gas. Seems to run better with the cowling on???<br />Any info would be greatly appreciated
