dmeckley12
Thread starter- Joined
- May 21, 2023
- 10
I'm having issues finding good electrical diagrams showing where wires are supposed to go on the terminal block, for a 1972 Evinrude 50hp selectric.
I just ordered the rectifier today. I should have it by Tuesday. Do I need to wait for that before I test for spark when the black and yellow wire is disconnected form the CD?Disconnect black wire with yellow stripe at the CDI / powerpack.----Test for spark.
I just kept it in neutral. I didn't select fwd or reverse.Does the gearcase shift for you ?
I do appreciate your help. I know I'm probably asking stupid questions.See post #9-----I started working on outboards BEFORE your motor was made.-----But it is your motor to work on and learn as you go.
Shouldn't it remain in Forward, as no power is going to the Neutral SolenoidRemove sparkplugs.-----Turn key on.-----Put control in forward.------Turn flywheel with socket and ratchet.----Should shift to neutral after about one turn.----Put control in reverse.-----Should be in reverse after about 2 turns.----Yes a good unit shift that easy !
