1972 Evinrude 50hp selectric
dmeckley12
I'm having issues finding good electrical diagrams showing where wires are supposed to go on the terminal block, for a 1972 Evinrude 50hp selectric.
Just to add ----your control box and motor must have that yellow plug.-----And 12 volts is only needed to crank it over and provide power for shifting.-----The magneto produces the spart and does not use 12 volts to do that.
dmeckley12
Thanks for the diagram. My outboard seems to not producing a spark. I originally replaced the rectifier, because I found frayed wires. Still no spark. I replaced the stator, CDI, and both coils. Still no spark. I read out the rectifier, and all wires show continuity no matter which way I have the black lead. Any other recommendations would be much appreciated.
Disconnect black wire with yellow stripe at the CDI / powerpack.----Test for spark.
dmeckley12
I just ordered the rectifier today. I should have it by Tuesday. Do I need to wait for that before I test for spark when the black and yellow wire is disconnected form the CD?
F_R
The rectifier has absolutely nothing to do with producing spark.
dmeckley12
I removed the black and yellow wire from the CDI. It has spark. I put the plugs in, and it wants to start but still no go.
If I picked up a 1972 outboard motor for cheap ??----I would tear it down and do a complete evaluation before spending any beer tokens for parts.----First post the actual compression values here.-------Is your battery top notch / load tested?----Is the starter in top condition ??----Does the motor shift properly?----All easy things that can be checked without any coins spent!!
dmeckley12
Well compression is good and the motor runs. Only when I manually open and feather the carburators. The controls are very stiff to move.
Remove sparkplugs.-----Turn key on.-----Put control in forward.------Turn flywheel with socket and ratchet.----Should shift to neutral after about one turn.----Put control in reverse.-----Should be in reverse after about 2 turns.----Yes a good unit shift that easy !
dmeckley12
I haven't tested the shifting yet, I am out and about. But how do I keep it idling in neutral. As of know I have to manually run the carburator controls, while turning both idle needles to find where it will idle by itself?
See post #9-----I started working on outboards BEFORE your motor was made.-----But it is your motor to work on and learn as you go.
jimmbo
Shouldn't it remain in Forward, as no power is going to the Neutral Solenoid
When motor is NOT RUNNING it will be in forward !!----Oil pressure is used to shift this thing.----With 12 volts applied ( key turned to on ) to neutral solenoid , green wire , oil is directed to shift to neutral.----When 12 volts is applied to green and blue wire it goes into reverse.-----But the motor must be turned as clearly indicated earlier.---That develops oil pressure!----Sorry----To me these hydro electric shift units are very , very simple.
dmeckley12
I put a socket on the flywheel and turned it as directed in post #13. I don't see anything moving other than the prop.
Gearcase must be full of oil ( type-C ) for electric shift.---- The shift solenoids are very secretive.----They are inside the gearcase and in the oil.------Find the shift wires going into the lower unit.---You can apply power there to bypass the shift switch and wiring.------It might be wise to get the shift sorted out.----Finding a shop to work on that might be hard and if they will , it will cost lots of beer tokens.
