1972 165 Mercruiser Block cracked
Sc25175
I have a cracked block in my 1972 Starcraft Chieftain 24 footer. Engine is out on a stand.
Question
The casting number on my block is 328576 I have found a donor motor from a chevy truck that has a casting number of 3921968.
the only thing I have been able to determine is these casting numbers where both being made in 1972.
Is there any way to figure out if I could use the block from the donor truck for the boat??? Thanks in advance
achris
More fish than mountain goat
Re: 1972 165 Mercruiser Block cracked
Most of the differences between marine and non-marine engine blocks of this era were the front mount bolt holes. Any replacement block you find will need to have the 'ears' at the front for the mounting. Also make sure they have screw holes tapped for the starter motor...
Chris....
Sc25175
I have confirmed that the bore and stroke for both casting numbers are the same. I am having the current owner check on the bolt holes for the front motor mount. He is also confirming it is a six bolt main.
Is there anything else I should be checking on? This could be a good deal $50 for a working motor.
Don S
What the heck is a 6 bolt main? I know some V8's have 4 bolt mains, but 6 ?
Sc25175
Sorry, used the wrong term. I meant 6 bolts on crankshaft to connect to the flywheel. Not much of an engine guy.
Question
Ayuh,.... How far away is the donor motor,... Don't trust the seller, he won't know what "Ear" yer talkin' 'bout....
Study the forward starboard corner of yer motor block, then go Look at the donor motor...
Sc25175
Thanks Bondo, the motor is 90 miles away so I am having him send me pictures, hopefully I can tell that is the same or different.
