robeffy
Thread starter- Joined
- Aug 10, 2014
- 11
Hi,
I was given a Sears ( Eska ) 4 hp outboard, model No 217-58580. Its complete, but did not run.
I was told it poured gasoline out, after being "put back together".
First thing I checked was compression, which is 55 psi. Seems pretty bad.
Next, I did some disassembly and bought a new spark plug, to replace the missing plug. There is a spark!
Removed the float bowl and there is no needle valve, and the float bowl will leak gas as the mounting area has been crushed and holed. Some form a gasket might seal it for a while..
The prop is pretty dinged up.
There was rust in the gas tank ( built in on the top of the motor ), I blew it out, but there were pieces about 1/8" across. Guessing the inside of the tank is bad.
This just seems like a wall ornament to me..
Thoughts?
I was going to hang it on the back of my CL16 sailboat and putter around. Don't really need it, have a nice Sea Nymph 16 ft side console fishing boat with a 55 lb electric....
Thoughts?
