1970 Mercury 500 Carburetor Leakage
indy82tx
I'm restoring an old tri-hull with a 50 hp Merc (4 cylinder,2 stroke, 2 carbs, fuel pump is not part of carb). I just finished rebuilding the carbs and fuel pump. When I prime the fuel, I have fuel driping out of the carb air inlets (both carbs). Any suggetions?<br />Thanks,<br />Ken<br />1977 Imperial Tri-Hull<br />1970 Mercury 500
petryshyn
Re: 1970 Mercury 500 Carburetor Leakage
Is it possible that you are squeezing the primer ball too hard causing the flooding condition? How does it run?<br /> :)
indy82tx
Thanks Schematic,<br />You may be correct. I was probably a little over-zealous on the priming bulb. The engine starts and seems to run ok. I've only run it for about a minute.<br />Would the engine being slightly tilted cause the leakage?
12Footer
Yes, it would cause that. The float would float at the wrong level, and overflow.
