1970 Larson Lapline - Floor Help Needed
OakdaleJohn
Seeking any and all pictures and assistance for tearing down and rebuilding the floor of
my newly acquired 1970 Larson Lapline runabout. It outside uncovered for years, so I'm sure the wooden floor under glass is probably toast. I understand there is some foam I'll need to remove as well. Anyone have pics of what that looks, or diagrams of the floor design?
JASinIL2006
I didn’t see any restoration threads of that boat here at iboats, but here’s one from fiberglass.com. Not sure what year it is, but it might be helpful.
TripleJGraffis
Welcome! My recommendation to you is to start with posting some pics so we can all see what you are talking about. Secondly, If you have a rotten floor, then you almost certainly have rotten stringers, bulkheads and transom. You will find that the flor is the least of your worries right now. Pull the floor, perform some core tests on the stringers and transom and go from there.
And regarding the foam....yes, there will most likely be some that you will need to remove prior to removing stringers or transom. Here are some pics from when I ripped up my foam. It was everywhere!
Best of luck!
