1969 mercury help
Bjohnson2345
So I'm starting a new thread so to fill ppl in on what's been going one first I started with a 1970 mercury 500 that came with a boat I bought, well as precaution I also bought a 1969 mercury 500 for parts, I started by trying to figure out why the 1970 what underpowered and wouldn't plane after a compression check and further investigation I found heavy scoring on the number 4 piston. So I decided to try and get the 1969 up and running I spent about a half day replacing the parts I borrowed from it, did a compression check on it first of course they where all around 120 so I put the motor on the boat and hooked up the harness and fuel line, hit the primer bulb and the choke and it fired first turn of the key. It want really loud but sound like it was running ok, so I got to looking around to find out why its so loud and I found a hole in the crankcase cover under carb 2. So my plan is to pull the motor back off and put the 1970 crankcase cover on the 69 but the cover is pretty dirty on the inside, and while I'm waiting for parts in the mail, I want to clean the cover up what should I use to get it looking like new again?
Re: 1969 mercury help
Sounds like a plan , but you must determine why that hole is there.------Sounds like something broke inside.----To me it sounds like you have 2 bad motors.-----Please note that these covers are doweled and may or may not be interchangeable.
Bjohnson2345
I'm looking for a lower end cap with good bearings and seals for the 1969 merc 500 anybody know where I can find one please help I have this same question on other forums without having any luck
Bjohnson2345
Need help finding lower end cap with good bearings and seals
I can't seem to find any lower end cap with good bearings and seals for the 1969 merc 500. Anybody know where I can find one? Please help, I have this same question on other forums without having any luck. Thanks.
Edit: Made the question and title more suitable for iboats rules vs just deleting it altogether.
Gibbles
Re: Need help finding lower end cap with good bearings and seals
have you been able to locate a part number for it?
Fun Times
Gibbles
Yeah... I'm not finding anything with either pn.
Totally check with several merc dealers, and try and find that shop that has been around for a while, sometimes you get lucky.
I found several impossible to find merc parts by checking an old shop...
Other than those ideas, keep checking ebay for those part numbers, like once a week or so for the next few months. ;)
Those shops like to clean their inventory on ebay...
GA_Boater
What's your serial number of the one you want to fix? Really, what are the serial numbers of both the 69 and the 70? I'm finding one for some serial number ranges, but need know your SN's to be sure.
Bjohnson2345
The 70's S/N is 2739033 the 69 I'm not sure of it 26xxxxx I'll have to look on the transome bracket in the morning cuz I can't find it on the block anywhere
GA_Boater
Here is a link with item #28 1102-1484A 1 replaced by 1102-1484A 3 replaced by 1102-4181A 1 End Cap Assembly
Mercury Marine 500 CYLINDER BLOCK AND CRANKCASE ASSEMBLY Parts
Kinda pricey at $80, but they have 10 in stock.
When you get the SN of the other motor we can figure out if they use the same end cap. The link covers SN 2305101 THRU 2858813, so it may be the same cap if the other motor starts with 26XXXXX.
Bjohnson2345
Thanks for finding that I was starting to lose hope that I'd find it
Many Mercury motors use the same end cap , seals and bearing.-Should bot be hard to find at all.
Bjohnson2345
Hey, GA_boater so do you or anyone else know if this assembly comes compete with seals and bearing I went ahead and ordered it assuming that it does then when I call the guy said he didn't know " cuz there's no pictures haha" but I would really like to know because at that price it's a rip-off to not be fully assembled hints the " assembly part of the description
GA_Boater
I don't know what is included in the assembly but no parts are listed for items 31-33, which are the bearing, O-ring and what looks like a seal. Maybe that means they are included. :confused: Let us know what you get.
Fun Times
I'd say the changes are good that it will come together vs not.
Someone ask for pictures:laugh: here's a used one that needs new bearing seals & O-ring.:D 1484A1 Lower End Cap Casting 1102 24 Mercury 500 50HP Serial 01843104 | eBay
Bjohnson2345
Will do!! I got a email today saying it was just shipped so I should have it in a few days.
merc850
So my plan is to pull the motor back off and put the 1970 crankcase cover on the 69....don't do it the covers and blocks are line bored together and you can't mix them up.
Bjohnson2345
I got the end cap today and it was complete with bearing and the seals the only thing different was the location of the o ring on the old one it was located in the center of the end cap on my new one it's more toward the end where the bottom of the block is whats everyone's opinion on this? Will this make a difference?
