1969 40 HP Johnson Erratic Idle/Rev.
The Starcraft Enterprise
Having some issues. When I finally get it started it idles rough. When I try to rev up the engine there 5-6 second delay when it goes from the rough idle to a higher RPM and then it eventually stalls out. I recently replaced the fuel pump. Any suggestions? The condensors, points and spark plugs all look good.
kfa4303
Banned
Re: 1969 40 HP Johnson Erratic Idle/Rev.
I'm thinking dirty carb and/or bad coil that only fires periodically. If the coils are original, then at least one as the original OMC coils had a 100% failure rate in time. Thankfully the new replacement coils are bullet proof and only about $20 each. You can get a carb rebuild kit right here at iboats as well as all your ignition components. You only need three things to get these big girls running again; compression, fuel and spark. Verify each of these before moving on to the next. These links may help too.
http://www.duckworksmagazine.com/04/s/columns/max/24/index.cfm
http://forums.iboats.com/showthread.php?t=167352
http://www.outboard-boat-motor-repa...on 3 HP 1952-1967 Ignition System Tune-up.htm
http://www.outboard-boat-motor-repa...hnson 5.5 HP 1954-1964 Carburetor Tune-UP.htm
http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1969&hp=40&model=40E69R
Thanks for the help. I ordered a carb kit. I pulled the flywheel and all the condensors, points and coils look very new. This motor was -given a tune up late last season, the boat has only been used five or six times since then. I am assuming its the carb, but I will check for spark anyway.
