1968 chrysler boat floor
Status
Not open for further replies.
i have a 14' chrysler and i was wondering about the floor i am redoing it beacuse i had a tear in the keel and took on watter and the perosn i boat it from put open cell foam ive already take all that out and now all i see on the boat is a beam and no ribs should there be ribs and how should i put this deck in
Re: 1968 chrysler boat floor
Ayuh,... Got any Pictures,..??
sorry no pics its winterized right now but it has a 4x8 and then 2 2x4 on top of the and thats it i gusse before the foam suported the floor and there was a soft spot betewen the floor peaces
pics of the boat
pics of the boat
this is the pics of the deck
Re: pics of the boat
Ayuh,... Generally speakin',... The Beams are called Stringers, 'n the Ribs are called Bulkheads...
Actually, Ribs, as in wooden boats don't usually apply to fiberglass...
It appears you have a 2x4 or 2, lain on it's side as a Stringer, right up the middle,..??
The bulkheads, or cross-ties appear to be broken,...
The wood strips/ stringers on the outside, are they furing strips,..??
they were held in by the foam you see some left but what would i have to do to this before puting a deck in
jonesg
Chrysler used structural foam instead of a lot of wood.
The foam I removed from mine was that same foam.
You can either go back with injection foam or gut everything out,
grind the glass and put wood back with glass cloth. The wood should be completely glassed to seal it, not just glazed with resin.
Chrysler resoration
Chrysler resoration
i am doing a restoration. i am putting a new deck in. i already pulled out the old one and olld the spray foam that was there. i am planing on puting some foam in some parts for support. today i cleaned it all up and am ready to put the floor in. i will post some picks when i get a change probally this weekend will need help along the way with puting the new deck in and fiber glass. thanks
Yacht Dr.
Re: Chrysler resoration
Why are you here on Iboat SBL ??
Stop your stupid posts.. I have semi-givin credibility to you on other posts..but you just dont get it.
Im done with you personally..and will ( the next time ) will make a soft suggestion to the Mods.
Peace Out !
YD.
Bob_VT
Spend some time reading all of the restoration threads. When you have photos ready 640 x 480 sized I want you to send me a PM and I will re-open this post up. So it is locked until you are ready to post the photos.
You stated in this original thread that the boat is winterized. Either you are working on it or you are not. DO NOT make up any drama to keep people busy. When you get further along let me know so for now this will remain locked until you are ready to show progress.
The restoration section is the most serious since people spend hundreds to thousands of dollars doing the repairs.
Status
