Nabstar
Thread starter- Joined
- Jul 7, 2011
- 41
Initially when I bought the boat, I field tested the strength of the transom by flexing the outboard. There was slight flex but about the amount you'd expect from plywood but not enough to be scared and the floor felt rather solid .... so I proceeded without replacing those items. What I've noticed however, is that the overboard drain hole in the splashwell has some cracks around it even after painting and seems to be adding small stress cracks which is what alerted me to begin with ..... that flex was becoming an issue. And all those little cracks have probably introduced water into the transom wood. During the resto I drilled holes at the base of the transom for underwater lights. The wood that came off the drill bit was dry but that may have changed now from water above.
All in all, I want to correct the problem in the proper manner, whatever that may be, but want to attempt to disturb the rest of the boat as little as possible since it's already "finished" & the exterior paint is beautiful.
