rk970
- Jul 15, 2013
- 74
Re: 1965 Pacific Mariner 16'
Some pics of were I am at. The side stringers in the center were not completely rotted (about 6' in the center) and had some integrity. I used two 2x4 to bridge across and hung the center keel/stringer from that when I bedded it in. I got a one layer of csm on the sides of the center stringer (extending 4" into the hull) I cut/ground out one side stringer. I hung the side stringer from the same 2x4 bridge that is now attached to the center and opposite side stringer.
I bedded in the side stringer with hairy PB, when that set I mixed up some micro and did the fillets. I will scuff/sand and put csm on the sides and into the hull (3"). When the csm cures I will cut/grind out the other side stringer..
I am doing it this way to keep the stringer in the original level plan.
rk
rk
