Woodonglass
Honorary Supreme Mariner
- Dec 29, 2009
- 25,932
Re: 1964 Johnson Tri-Hull restore!
Should I be using something other then ply to fix this hull since its below the waterline?
Not sure I understand this statement. You will NOT be using Plywood to be fixing that HOLE!!!! You will be using resin and glass!!! ONLY!!!!! Muliple layers. Once that is done THEN the Plywood Transom will cover it. You will then re drill the Drain hole and reinsert a Brass Drain tube. At least that's how I would do it. I would also be doing some glass work on the outside of the hull in that area as well.
As for your stringers you might want to look into SeaCast or Nidabond.
I'm just sayin...
I'm just sayin...
