1962 Merc 450 restoration ..
jimmbo
Looks Good
Make sure that there isn't any paint to interfere with the Propshaft Bearing Carrier, and Seals
sphelps
How do we get the tapered roller bearing racer out of the back of the LU ? Is this gunna take a special tool ?
Honorary Supreme Mariner
Using a bit of heat ( propane torch ) the bearing will usually fall out on the work bench.
sphelps
The bearing is out . It’s just the racer that’s still in there .
I’d rather not put a torch to my new paint job .. 😳
sphelps
I guess I should have done that before paint … lol !
jimmbo
Perhaps putting it in the Oven at 350 for an hour would warm up the Aluminium enough to let the race fall out, plus give you some Baked-on Enamel;)
sphelps
Bearing carrier is out . I picked up a tool similar to the one jimbo posted . Now how do I put the new one in without messing it up ? Can I take the old carrier and lay it on top of the new one then use a block of wood or something to tap it down in place ?
sphelps
Ok Bearing carrier in place . Got this set . Didn’t have exact size but was able to get next size up and turn upside down for a nice flat surface . That also allowed me to leave the disk bolt on the shaft . I would have had to remove the bolt if I used the disk the intended way . The bolt would have distroyed the SS keeper .. image.jpg
sphelps
So is this how the seal should look ? It’s different than the original one .
The bushing assembly came with a seal already in place . With I guess 2 extra seals ? And I ordered a seal not knowing the bushing came with them . So my question . It only get one seal correct ?
sphelps
Every little thing is an accomplishment LOL !
A washer ground down to fit . 53 cents . HF puller and a lot of heat and pb blaster .. A few choice words and that tapered bearing finally gave up .. LOL !
